Stock Size Cancel
Hi. How can I cancel stock size command? Can you help me please.
Re: Stock Size Cancel
Could you give more details ?
I completed the command. I don't want him to choose the first choice when I enter the command again.
is this something related to piping stock?
Best Regards
Kapil
No. A command in Mold Wizard. You can find attached picture.
It could be dialog memory.  Your options are to reset the dialog (select the icon with the curly arrow on the top right of the dialog) or disable dialog memory in the customer defaults.
