Re: Suggestions about using arrangements with routing
It does not work for me. When I try to create a path to the individually positioned components, I have an error.
What is the exact architecture of your assembly?
I can't make a path to adapt to the new components either. Even if end constraints are suppressed for the arrangement, path ends do NOT move under the new constraints.
(view in My Videos)
I am sorry.
As I try it again.
My method is not work for component case.
I just try it with 2 datum csys within assembly itself. (instead of components)
Try to control assembly dimension of RCP with arrangement.
(without constraint between components)
 Sunkap Ahn, Senior Support Engineer
logo
Even with CSYS at the assembly level, it still doesn't work.
(view in My Videos)
In this case, you cannot use contraint command from Shortcut Minibar.
Try to click Assembly Constraint command first.
And then select each point.
logo
Now without any screenshots the whole thing is becoming increasingly pointless. Please provide visual examples of your exact acrchitecture and shape of a routing path. It might be that under some specific circumstances your suggestions would work, but I suspect that they are not usable for the general situation.
Sorry
I cannot uploal any image or movie file by our company security policy.
And i making this post with my mobile phone.
As i said, my first method not work for component case.
So I suggested another way.
You trying to move some component first.
And according to reposition of components by arrangement, routing path is moved sametime.
This approaching cannot be applied.
But another suggestion.
You can create routing path and control it with arrangement & constraints.
And then create additional constraint with path and components.
Then Reposition of path will drive component position.
logo
