Suppres message "new iray+ ray......"
Hi all,
does anyone know if there is a setting the default hide the messages:
"new iray+ ray traced studio rendering"
This messages pops up when opening a old part in NX11 and higher.
Is there a varaible that can be set?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
8 REPLIES 8
Re: Suppres message "new iray+ ray......"
Hi @ruud_vandenbrand,
Env variable is NX_RTS_IRAY=0
@GaneshKadole
i have just tested the variable.
it hides default te message but also it turns off the Iray.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi Ruud,
When i select the "Don't Display This Message Again" option then i never get this message again.
Do you still get the message popping up again?1_1_3.jpgBest Regards
Kapil
@kapilsharma I know that option.
We are using a compare tool at a customer to check if there are issues between parts opening in NX8.5 and NX11
one of the "errors" is this message.
So i want to turn in default off for all the users.
I hope that there is a varaible or a registry to set for this message.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi Ruud,
Sorry for sharing an obvious suggestion. I have no clue how to set it through env variable.
Best Regards
Kapil Sharma
@Ruud_vandenbrand wrote:
@GaneshKadole
That's right.
Best I can suggest...
Export the entire registry key for the user before the "don't show this again" option selected
Export again after setting that check.
compare the .REG files.
You might also want to save the user.mtx file before/after (I'm not sure where this data is stored)
The registry key containing the nag screen information is called Hide_message.
For NX 11.0.x it is:
HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\11.0\Hide_message
Each NX release has its own and the values might be different, so checking the difference is worth more than a corrupted registry.
