Surface area Calculation in Assembly
I have an assembly file consisting of lots of parts. I want to know the surface area of each part individually. Is there any way we can introduce some macros for calculating surface area?
15 REPLIES 15
Re: Surface area Calculaiton in Assembly
Try this journal:
assembly_surface_area.vb
It hasn't been thoroughly tested, so post back with any errors you encounter.
It runs without throwing any error..
Thanks a lot for your help..
Spoiler
 Man Happy
The only problem that I am facing now is whenever I use a large assembly file. I have few parts which have referenceset as 'Entire Part'. For that following parts I am getting surface area as 0. Do you anything about reference set? How do I overcome this problem?
Also can I create a similar kind of journal to give a list of surface areas of an individual surface of an .iges file model?
Updated to handle the "empty" and "entire part" reference sets. Download from the same link as above.
It works now...Smiley Happy
I wanted to know what modification I must do in order to get surface area of individual surfaces of an part? I will be using imported .iges file so that I can have each surface as a different body(entity).
As for measuring surface area of individual faces, I'd suggest iterating through the part's body collection, use the .GetFaces method, and finally use the measure face command on each. Record a journal of measuring one face in a part to get an idea of how to call the correct measurement functions; use this code as a starting point.
Thanks.Smiley Happy I will try doing that...Smiley Happy
Plz tell me how to use attached assembly_surface_area.vb file.
In modelling window; go to Tools>Journals>Playback
A window will appear. Browse the .vb file and click open. You will now be able to click on 'Run' option.
