Sweep Along Guide / Swept / Variational Sweep
I am trying to sweep a curve along the guide line and the body is intersecting itself creating a void.
Anys suggestions would be helpful.
I saw few tutorials on youtube but didn't help. Please redirect me to useful tutorials or a solution to overcome this. Thank you
8 REPLIES 8
Re: Sweep Along Guide / Swept / Variational Sweep
Hi @TejSwaroop
Which of these 3 commands did you use?
As you have sharp corners in your guide curve Sweep Along Guide is more suitable.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help#uid:index_modeling:xid868388:id651751:swe...
Also if possible, zip part file and attach to post.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
@robot139 and @SamadhanGaikwad
 Thanks a lot for the response, been trying to work my way in solving it for a week.
I tried swept and variational sweep, but couldn't make it work.
I am attaching the prt file.
Thank you
Hi @TejSwaroop
I don't think it can be done in one step. I attached my solution.
@robot139 , I can see that you've saved part in NX1847. Do you have any NX11 release as @TejSwaroop  has tagged and also part history indicates he's using in NX11?
If you don't have I can create one in NX11 with your method and attach here.
@TejSwaroop , I also tried many things with sweep features but no success. I find @robot139 's solution quite befitting here.
Samadhan
Hi @SamadhanGaikwad
Ah I didn't think about version. You are right. So I send a picture from my part navigator and would be thankful if you reconstruct it with NX11.
I am sure you'll get the method easily.
Thanks.
@SamadhanGaikwad  and @robot139  thanks for the help guys.
I am not able to open the prt file because i am using the older version. Please upload the compatible file.
Thanks againSmiley Happy
@TejSwaroop , attached the part from NX11 with @robot139 's solution.
Samadhan
