Swept Volume
Hello ,
I'm looking for a way to swept a Volume without Substract or Intersect an another volume, Swept Volume function works with operation boolean. Most functions use curves for the section , I would like a solid for section and curve for guide
Thanks for your help
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
4 REPLIES 4
Re: Swept Volume
Do a command search for swept volume it is new in NX 11.  Works well
Re: Swept Volume
Ok , but swept volume works with boolean operation (intersection or Substraction) , for me I have a solid and a curve
like below image & i would like this result (2nd image) :
www.adgroupe.com
Re: Swept Volume
Create a bounding box around the curve. Then you can choose intersect when creating the Swept Volume.
Re: Swept Volume
yes , thank you both
www.adgroupe.com
