Do you mean
Reply
Synchronized desing in NX 9 ?
[ Edited ]
Hello
I used earlier Siemens Solid Edge it had a some kind of a steering wheel to "synchronizingly" design parts or so...
Now does NX 9 have same kind of synchronizise design ?
  • I'd like to move (3)three holes using synchronize...on a body(=part that has no features)
  • I found move face is that it ?
Re: Synchronized desing in NX 9 ?
You are in the correct command, but at the moment your dialog shows you have your motion set to "Distance" which assumes you will supply a vector and value.
If you want the OrientXpress tool to come up you need to change your motion type to DYNAMIC
You will then see the handles that you are looking for.
Paul Brown
