TcE Multi level Structure Manager BOM need to pack the child components
Hello
Not sure whether i can ask this here or not.
TcE Version : 10
Nx Version : 11
In TcE Structure Manager while working in a huge assembly i need to multilevel BOM to excel but need to pack all the childs. For example if 10 bolt (Same part number) is there then it need to be appear as 1 line item (As like Nx Assy. Navigator Pack all option).
thanks in advance.
Sekar
8 REPLIES 8
Re: TcE Multi level Structure Manager BOM need to pack the child components
Hi @Sekars ,
Under view dropdown menu, there are options Pack All and Unpack All. Select top bom line and click 'Pack All'.SM_Pack.jpg
After seeing your post,i tried this but not working.
@Sekars , Do items (same item) have different find numbers ? If yes then they will not pack together.
There is a Teamcenter site preference "BOMExcludeFromPackCheck". By default it is set to 'none'.
If multiple instances of same item/bom line have different find numbers, then they will not pack together. If you add value 'seqno' to this preference, then irrespective of find numbers all bom lines of the same item will pack together with respect to their level.
Note - After adding new value to preference, it will be needed to restart Teamcenter.
Yes, here find number is different. Because of this only i could not able to get this.
So you need to edit TC preference as suggested.
Please elloborate  how to change / set the Teamcenter site preference "BOMExcludeFromPackCheck".
Note that it is a site preference so you will need DBA role/privilege to edit it. Restart Teamcenter after editing preference.
(view in My Videos)
Thank you
