Team center-How to find the history
Dear community,
In Team center how i can retrieve the list of components which i created on my login.Because i removed many of the files to make home screen clean.But i need some of the files which i removed(using cut option).
Re: Team center-How to find the history
Use the General Search option in Teamcenter.  Enter "*" for the Name and for the Type use "Item", "Item Revision" or "UGMASTER" depending on what you want to find.  Use the Created After option to define a date after which your component were cut.  For example, enter yesterday's date.  Hit the green magnifying glass icon to execute the search.
