Text Problem in NX10 Linux Version
Hi
I cant found the Text function , even when i type 'text' in the search !
Re: Text Problem in NX10 Linux Version
Hi @Kutayba,
The Text command is not available on Linux or MacOS versions of NX.  The command creates curves from True Type fonts found in the Windows font library.  Here's the link to the documentation.
ER 8326290 was submitted requesting similar functionality for these platforms.
Regards, Ben
