The 2d drawings
Each time you do the engineering drawing the reference frame will be projected and this projection doesn't seem to work, and the drawing is very messy
Re: The 2d drawings
Hi @FZK,
Menu > Format > Layer Visible in View.
In your model datum CSYS is present on layer 61. So make layer 61 invisible in that particular view.angle.png
Ganesh
Re: The 2d drawings
thans you .
Re: The 2d drawings
Hi @FZK,
Have you suppressed layer 61 after creating the view?
If you suppress the layer after creating the view then it will not update. You need to create the new view.
Other way is simply show and hide the Datum CSYS from part navigator in the drafting application to update the already created view that will hide the Datum CSYS.
Ganesh
Re: The 2d drawings
HI Ganesh_Kadole
The problem has been solved, this is skillful.。
thens you
Re: The 2d drawings
@FZK
The easiest would be; in any application, i.e. Modeling or Drafting press Ctrl+W and select (-) of what you don’t want to see.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Re: The 2d drawings
HI mike_fdo
Install your method, and you will also be able to do some unnecessary coordinate systems in the anctrl + shoft + U drawing environment.
thans you.
