The specified MatML is not on the search path....
when I export new materials on our shared material library an error came out.
What does it mean and how can I correct to avoid this message ?
Thank you..
Using NX1880 and RuleDesigner PDM
Built-in functions for converting units of measure
Re: The specified MatML is not on the search path....
Have you found the solution for this problem?
I just started to add my own materials and bumped in to the same problem.
Hi @maisbonden ,
as you can see in the image, there is a path, that doesn't match with the path present in the customer default, this is the message meaning, but it's not a real error.
Thank you..
