Thickness Dimension
I work a lot with imported models.
Most of them are originally made with CATIA V5 and then stored in TC with the JT put at disposal.
Such JT always contains exact geometry.
Most of the times the Thickness Dimension command does not work properly.
Am I doing something wrong?
This kind of errors occurs since I can remember that such function was implemented in NX.
Many thanks in advance for your kind support.
