Through Curve mesh, Drafting
Dear All, Recently I'm making a Drafting sheet of a object which has been designed using "Through Curve mesh" . When Drafting such object and creating section views, it create silhoutte lines(please correct if spellings are incorrect)/splines which is really disturbing when putting dimensions. Can't it be like other solid models? or is it a issue with my design methodology.
I need help to solve this issue.
5 REPLIES 5
Re: Through Curve mesh, Drafting
Ciao @BHANU_1,
correctly configure the views according to your needs.
Ciao
@BHANU_1,
This is typical of NX freeform features; Ruled, Through Curves, TCM as well as many others will result in geometry that is more often than not spline based. If you desire more analytical results (lines/arcs), then the models need to be created in a different manner, if it's even possible to do so.  The model with which you're working may not be able to be designed in any manner other than using TCM.
Tim
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.6
Hello Tim,  Can you please be more specific about TCM?
Thank you
@BHANU_1,
TCM = Through Curve Mesh.
Tim
GM TcE v11.2.3.1
GM GPDL v11-A.3.6
Got it, Thanks
