Tolerance analysis for parts assembled -NX10
Siemens Builder Siemens Builder
Siemens Builder
Hi Experts!,
I have been delivered a Transition Training for a customer
and as a result some questions were done.
One of this questions is related to which NX tool have to be use to analized
assembled tolerance parts.
A participant comment me that in the past this kind of analysis was done through PMI
and want to know if now we have to use any other NX tool.
I do not know if it is possible do same as with Clearance Analysis but I am afraid this Clearance Analysis
do not cover Tolerance and with PMI I do not know how to do to get tolerance analysis.
Do You know how to proceed? Are there any document that clearly explain the whole process to do this?
Thanks in advanced for your help...
Fidel
5 REPLIES 5
Re: Tolerance analysis for parts assembled -NX10
There used to be something inside UG/NX.
I THINK After they bough Tecnomatix, the UG module was dropped in favor of the Tecnomatix product.
Or else it was someone else they bought, or just a different product.
Unfortunately I don't remember the name.
I think the question was refering to TSV (Tolerance Stack Variation) which was available in NX 32 bit.
This tool was never available in NX 64 bit.
I think the replacement for this is Vis VSA (which is available within Teamcenter Visualization Mockup)
Siemens Builder
thanks Ken,
as they do not have Tecnomatic ....is there any other solution for NX?
Siemens Builder
thanks JAcosta,
as they do not have Vis Mockup ....is there any other solution for NX?
