Topology Optimization: Can not choose face
NX design optimization can not choose the surface, the experience is not very good.
Re: Topology Optimization: Can not choose face
if i'm correct you need bodies to select, so the simulation can calculate the keep-in/out
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
You need something there to pick. If you use Holes they show up in the list, in addtion you can create other bodies to pick. In this example the big block in the middle was added in and the selected as keep out. You can add extrudes and cylinders into the list.
TopOpt.pngOpt Features Scott
