Topology Optimization NX11
Hello guys,
I'm writing my thesis on additive manufacturing and I need to use the tool NX nastran optimization topology on the program NX11. I don't know how to use this tool, so I'm trying to learn. I have some problems on the settings for the analysis. These pictures are the screenshots of the windows in NX11 where I have some problem for the optimization.
In the first one, I don't know how to set the numbers, because in a tutorial on youtube I have seen the the value "Residual Mass (ITORMASS)" was set at 0, but in my case this doen't work, I got another error. So I set the numbers as you see in the Figure1 but I don't know if it's right.
In the Figure2, you can see the menu for setting the output "Normalized Material Density". I set everything as you can see from the picture, but I don't know if it's right again.
In the Figure3, after the analysis I check the "Normalized Material Density" but I can't get a good result because everything is with the number 1, nothing was optimized.
Can you please help me? or maybe do you have an handbook about NX nastran optimization topology?
Thanks for the attention and for your help,
Re: Topology Optimization NX11
Hi @VincenzoL,
You might also want to try on teh SimCenter 3D part of this community, you might get faster/better answers there.
https://community.plm.automation.siemens.com/t5/3D-Simulation-Simcenter-3D-Forum/bd-p/Simcenter_3DSi...
Kind regards,
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
