Track Drawing Changes - auto save data?
I could swear I saw this somewhere (customer default? preference?), but now I can't find it.  Looked in the solutions database and didn't find anything.
NX10.0.3.5, TC11.2
Is there some way to automatically save the drawing compare data (baseline snapshot?) every time a drawing is saved?
I don't want to have to rely on users creating the permanent "snapshot" data before a part is released.
Looking to compare the prior revision of a drawing to the current revision.
Thanks...Ken
Re: Track Drawing Changes - auto save data?
Ken, it looks like there is a utility program to generate a snapshot. You could add a routine to the release process to make sure that it gets run.
http://docs.plm.automation.siemens.com/tdoc/nx/10.0.3/nx_help/#uid:index_drafting:id968192:xid683894...
Scott
We have a program that does several things during a drawing release.  Creating a snapshot is one of them.  That would be gret if there was an automatic or version to version check vs creating a snapshot at every release.
Maybe you saw the "save Drawing CGM data" Checkbox in the save options?
Scott - your link doesn't work for me.
Could you post the title of the article or the path in the table of contents or ?
Thanks...Ken
That's different functionality than Track Drawing Changes.
Larry Carpenter, P.E.
nevermind, finally found it.
Note docs point to UGII_BASE_DIR\ugii\ugsamples\TrackDrawingChanges, but it is really UGII_BASE_DIR\ugsamples\TrackDrawingChanges (no "\ugii\" folder)
