Translate files to JT usign a batch
I am looking for a way to transalte STEP or IGS files to JT usign a batch, like the standalone translators in NX (see image).
Is there any way to do the same to translate STEP to JT? Without having to upload everything to Teamcenter of course.
Marc.
Re: Translate files to JT usign a batch
You can run the ugtopv translator from a command prompt once you have NX files. You could convert them from STEP using the command you have above and then to JT.
UG to PV Command Line
Scott
Looking for other translatators I found a file named "jt_catiav5.exe" in "ugnx90\CATIAV5\pscatiav5". Is there any way to use it to translate Catia5 to JT directly?
I also found that I can borrow a license CATIAV5TOJT TRANSLATOR but I don't know how to use it now that I get it (see attached picture)
Marc.
