Trasparent components in drafting shaded view
I've a shaded view and I want to show component inside in drafting view, like the image attached.
Thank you...
Using NX11 and NX1847 serie
RuleDesigner PDM
8 REPLIES 8
Re: Trasparent components in drafting shaded view
Hi cubalibre,
I am sure you have already tried using "Paqartially Shaded" view ... i cannot think of anything else as of now.
Best Regards
Kapil
Hi Kapil,
I remember that this is the solution, but I don't remember the process to obtain this.
Youtube is block at work.
Thank you...
RuleDesigner PDM
Hi cubalibre,
ok no issues...here is the documentation link .
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help/#uidSmiley Tongueref_shaded_partial_vw_ht
Also i am attaching a youtube video on partially shaded view herewith.
(view in My Videos)
Best Regards
Kapil
As far as I know, you cannot change the transparency of a component in a shaded drafting view.
Hi @cubalibre00,
The following documentation should help you: Add partial shading to a drafting view
You cannot inherit partial shading applied in modeling.  Having set the Rendering Style in the view Settings to Partially Shaded, you have to use the View Dependent Edit command to apply partial shading to the bodies in the drafting view.
Regards, Ben
@BenBroad,
Good information to know. I've learned something new today.
Hi Ben,
Thanks for sharing the information. I was just checking the modelling partial shading option ...looks like we can bring in the shading in terms of colors but not transparency (for that we have to undergo the view dependent option). Please do correct me if i am wrong.
(view in My Videos)
Best Regards
Kapil
Hi to all,
thank you for suggestions.
Solution was :
1) View in shaded mode
2) View dependent edit -> Edit shaded object -> Select external body -> Traslucensy 50%
Thank you...
RuleDesigner PDM
