Re: Trim function disabled in NX11
In the drafting application, go to customize, search for "basic curves", drag and drop the command to the desired ribbon.
Thanks Cowski, exactly what I did. Good thing Siemens just keeps coding over old commands like basic curves...
Hello Wolken,
Same as any other commands: right-click the ribbon tab and select "Customize", then use the search option there to search "basic" which will give you the command to drag to your preferred UI/ribbon location.
