UG Detailing Display format issue
Hi ,
I am new to UG ,
I have an issue please help me to resolve it....
UG Deatiling is getting bold and not fitting in the table.This is issue occuring fewer workstation
and user are telling it is an graphic issue...
I have attached screen shot with highlated mark, I hope it will give more clarity.
Regards.
UG-Cub
5 REPLIES 5
Re: UG Detailing Display format issue
It appears that the issue is caused by the Text Font settings on the affected stations.
Use 'File -> Preferences -> Drafting -> Common -> Lettering
Review the Text Parameters and verify the font is correct.
Hi Rony,
Thianks for the quick response......
I have cross checked the drafting tab and change the setting to standart format.After changing the format ,I am able to fit the content inside the table but not the font.
Ex:if i select font to "Regular" but displaying in "Bold",please guide me
UG-Cub
Is this table a tabular note?
~Sen
Hi Sen,
Its a title table....
UG-Cub
You can try edit annotation command.
then click settings and change the lettering style there.
In my PC, even if I change the drafting preferences, not all the notes are adapting.
This is what I do whenever I need to change some of the text.
Hope this helps.
~Sen
