UGAnswer link?
Has the link to UGAnswer changed?
I tried some general searches - all leading to dead-ends. One of which is:
http://uganswer.ugs.com/qcksrch.stm
Where is UGAnswer found, please?
Steve A.
SteveA
DRT Mfg. Co. Inc.
www.drtusa.com
Win7x64 NX8.5.3.3
11 REPLIES 11
Re: UGAnswer link?
Siemens Legend Siemens Legend
Siemens Legend
it works for me. You need to use your webkey to login.
Jerry
Jerry Sarfati
Siemens PLM Software
Re: UGAnswer link?
The link takes me to:
How do you get to UGAnswer from there? I am looking for .Net code samples (but not the ones in the community postings).
Steve A.
SteveA
DRT Mfg. Co. Inc.
www.drtusa.com
Win7x64 NX8.5.3.3
Re: UGAnswer link?
I use this:
https://solutions.industrysoftware.automation.siemens.com/adv_search.php
dumps me directly into advanced search.
SteveA - click on the "Advanced search" to the right of the text box.
If you haven't used  this in a long time, the UI changed - you have to search FIRST, then filter based on what you want (e.g. example API code) after the search returns.
Re: UGAnswer link?
Thanks for the reply Ken. I have used this new search interface to search in general - but I don't believe that there is a filter for .net code examples (like I also believe there used to be in UGAnswer). I could have very well missed seeing a filter for this.
In general the filtered searching approach works fine - it's typical of a lot of retail applications which let you narrow down product searches.
Steve A.
SteveA
DRT Mfg. Co. Inc.
www.drtusa.com
Win7x64 NX8.5.3.3
Re: UGAnswer link?
Honored Contributor
Honored Contributor
I think "Sollution Center" is the replacement for "UG Answer".
-Dave
Re: UGAnswer link?
Thanks Dave,
Unless I have a faulty memory of UGAnswer - I can't easliy find now what I used to find in UGAnswer.
SteveA
DRT Mfg. Co. Inc.
www.drtusa.com
Win7x64 NX8.5.3.3
Re: UGAnswer link?
I'm OK now. I need to filter on NX API.
SteveA
DRT Mfg. Co. Inc.
www.drtusa.com
Win7x64 NX8.5.3.3
Re: UGAnswer link?
https://solutions.industrysoftware.automation.siemens.com/adv_search.php is the link I always use to search. You can filter before the search for NX API (see the attached image). You can't browse, but it will one character search if you like.
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
Re: UGAnswer link?
As you discovered, you can still filter on "NX API", as you always could.
As far as I can recall, there was never a filter that would let you get only .NET examples (as opposed to Java or C++ examples, or whatever).
Personally, I don't mind the lack of language-specific filters. If I can find code written in any sensible language, it typically helps me write code in my current favorite language. And these days there are even tools to convert code between languages.
山田
yamada
