Re: UGZIPC 64-bit
PLM World Member Creator PLM World Member Creator
Hmmm...mine is set up the same way except the menu item appeared without using customize. I must be missing something.
Re: UGZIPC 64-bit
John,
Oops, I failed to remember and state that I was using UGZIPC in NX 7.5.
Your copy will load and run in 9.0 but it still truncates the file paths and then fails to find them when zipping, just like the older copy I have was doing in 7.5.
I am hoping there is someone who knows how to fix this and would compile for both 7.5 and 9.0.
Thanks.
Cliff
Re: UGZIPC 64-bit
Does anyone have this utility running with NX11?
Re: UGZIPC 64-bit
Honored Contributor
Honored Contributor
This runs on NX11 Windows10 for me in native, will not work in managed mode.
-Dave
NX 11 testing NX1847+ | Teamcenter 11 | Windows 10
Re: UGZIPC 64-bit
Thanks!
