Unable to open variant Item in UG-NX
Hello Guys,
I have configured and create a Classic variant Item from a root assembly in Teamcenter and when i try to open the variant item in NX, CAD Model is not getting loaded as per the configuration rather it loads the model of the entire root assembly. Is there a wayout/preference to sort out this issue. I am using TC10.1.4 & NX 9..0.3MP6
Thanks & regards,
Dinesh.B
Re: Unable to open variant Item in UG-NX
Did you saved Variant rule in Structure manager? after saving rule in NX assembly load options select varaint to load and select rule. check once again assembly load options in varint load tab should have varinat name (rule). Load the assembly it will load configured assembly.
