Unable to reference parent objects that are deleted.
Hello, I added a feature to a part while in an assembly.  Evidently the feature was tied to a parent in the assembly and now the parent is deleted.   I keep getting this message:  "Warning: Unable to reference parent objects that are deleted.", but I don't see any problems or external references in the feature itself.
Are there any recommendations for how to fix this supposed problem?  Thanks
Re: Unable to reference parent objects that are deleted.
I eventually edited the feature while the part was the displayed part and reattached the sketch.  Even though it seemed that everything was the same as it was before, the warning disappeared.  I'm still not sure what the problem was and didn't see anything besides that initial warning that indicated what features were being referenced, but at least it's fixed.
I've found intersection curves/points in sketches that get theese type of errors, are harder to track down, ie less obvious.  That's usually where I suggest starting.
Glad you got it sorted.
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Good recommendations.  Thanks
