Unsuitable OM object ? Body measurement
Hi
How to fix the body measurement if it gives an error:"unsuitable OM object" ? (Also does not update mass on drawing sheet, outdated mass.)
  • Chain-symbol also broken with "!"-marking ?
Re: Unsuitable OM object ? Body measurement
The image you shared with us shows that there is no solid/sheet body in the part navigator so what exactly the Body Measurement measures?.
Can you please share the part file if possible.
Kapil
I founded solution: Changed some Pxxx and it worked.
  • Why a direct reference to mass P546 gives an attribute type(string) error ?
"kapilsharma"
Hello it is an Assembly-file.
How can I make parts outside drawing sheet visible ?
  • This never happened with Inventor, Pro-e or solidedge... Seems NX only issue ?
I am not aware of any option for making things outside the sheet visible but to me it seems more viable to either change the sheet size (Right click the Sheet Below drawing in the Part Naviagator and choose EDIT SHEET and chosse a bigger size) or else you can reduce the scale of the view to let it fit inside.
Sorry i cannot be of much help to you.
Kapil
