Up/Down/Left/Right for dragging or rotation?
Is it possible to use "Up/Down/Left/Right" keys to do dragging or rotation in NX?
Since long I want to ask about this. Thanks!
Re: Up/Down/Left/Right for dragging or rotation?
@surfactant
You are talking abour mouse gestures mapping to keyboard, & as far as I know (I might be wrong), we can't change those (or add new keys for those, as in your case).
I can suggest you one thing though. Go to the customize dialog (File>Customize) or hit ctrl+1, select keyboard. From there, you can atleast assign a shorcut key for everything; including pan & rotation.
Best Regards,
Paras Raina, Technical Head, MSC Systems Pvt. Ltd. (India)
NX 12.0.2
Solid Edge 2019
Hi @Paras_R
I just want to know whether it is possible to use "Up/Down/Left/Right" keys to do dragging or rotation in NX.
For  example, you create a straignt line and then need to adjust the positon of its start/end points. It seems that you can't set keyboard shortcut for dragging a point, either in sketch or outside sketch.
Thanks!
@surfactant
My bad. I took your rotation word in consideration and thought you were asking for view controls.
NX 12.0.2
Solid Edge 2019
Hi @Paras_R  Anyway, thanks for your reply!
No problem @surfactant.
As for the original question, I don't think it is possible to map the keyboard keys to adjust an under-constrained geometry.
Any chance for you to use a spaceball?
NX 12.0.2
Solid Edge 2019
Hi @Paras_R    I don't have a spaceball. Many years ago, I often drew simple geometries in Microsoft Word and found Up/Down/Left/Right can be very good alternative to mouse dragging in positioning some objects. That's why I post this question. Thanks!
@surfactant
I understand. Keyboard can be a very good alternative to mouse, but 'not so good' in our case, while using NX.
Mouse FTW. Smiley Happy
NX 12.0.2
Solid Edge 2019
From Windows Conrol Panel go to Ease of Access Center - Make the keyboard easier to use
 Turn on Mosue Keys
then can use number pad when num lock switch off.
Steve V
Hi @StevenVickers
Following your setting method, the number pad only moves the mouse cursor, but can't drag&move objects on NX. Do I miss something? Thanks!
