Updating Centerlines
I have several cylinders welded together forming a single long cylinder assembly. After modifying some of the cylinders by increasing their heights, i see that 3D centerline in the drawing does not follow and remain short. Is there a way to automatically update this?
Re: Updating Centerlines
Probably not. You can delete the existing centerlines from the view and use 'Automatic Centerline' command which will create a common centerline to the cylinders.
Ganesh
