Usage of commercial part as material
Hello!
We're in the Solution design phase of TC and I have some questions for the Material Management.
The MBOM needs to know from what Commercial Part a part should be made from (in order to choose the correct Vendor Part).
Hereunder, this is how we'd like to handle our materials:
In the NX Design, Engineering specifies the Commercial Part to be used (sheet, rod, ...).
Is there a way to show this in the ootb solution? (using IMM?)
I have a feeling that only the "substance" can be applied to an NX part.
Thank you for your answers,
Jonathan
Re: Usage of commercial part as material
No one has a hint?
When we make a part starting from a commercial part we create assemblies where the comercial part is a component and there some features in the assembly level. That is valid for us.
EDIT: I see now that you speak about "raw" materials as sheets and rows. I though you were speaking about parts manufactured from a different kind of commercial like screws... I think you need a different method, sorry.
