Use of Callout Attribute in Partlist in drafting
Hello People,
What is the use of Callout atrribute in drafting i.e when creating part list....What is the necessary situation to use this callout attribute and how to use this callout attribute....
And when i am checking the attributes tab there are Four types  Component, Part, Instantance and Reference set...What are the roles of callout in these Four Contexts.....Please find the Screen Shot of this...
What are the differences between COMPONENT, INSTANCE AND PART......
Re: Use of Callout Attribute in Partlist in drafting
Here is the link to the documentation that's descripes what it means
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.1/nx_help/#uid:xid1128417:index_assemblies:intr...
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Remember, when any dialog is open, you SHOULD be able to hit the "F1" key and get context-sensitive help (i.e. help about the dialog you have up)
