Variable data in mold base's data base in mold wizard
capture_1.JPGCan you explain me, what "U_h" variable means? because I try to changed the variable with different number, but there is no different.
Dear all,
I want to make custom variable in mold base's data base in mold wizard. I try to breakdown every variable in data base in excel. I stuck in change variable "U_h". Anyone can explain me, what "U_h" means?
thanks
Re: Variable data in mold base's data base in mold wizard
Sorry i have no knowledge about mold wizard but i guess it relates to the height of a mold plate (probably you might not be having that plate in your mold stack currently so could not see the difference.
Best Regards
