Variational Sweep produce not linked expresions of secondary sections
Hi everybody,
few months i am using function Variational Sweep spare Law Extension and Swept. I am very satisfied with this. Now i want to add some secondary section which will be linked on base section only one parameter will be change. But Parameters of secondary section are not linked and on top of it they are absolut diferent from base section. It is possible it makes selected sketch. When yes how is it possible to fix?
Thanks for reply
Re: Variational Sweep produce not linked expresions of secondary sections
Hi GrLoki,
Please have a look at the answer in your other post regarding Variational Sweep. Follow the link below:
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Variational-Sweep/m-p/399726#M12571
Best Regards
Sandman
