Vary constraint value in different arrangements
I have an assembly with some constraints created between parts. I want to have the different value for the same constraint in the different arrangements. For example, In an assembly there two parts (simple blocks), I had created the two arrangements and a distance constraint with expression having value say 50mm.
In arrangement1 I want the distance constraint value as 75mm and in arrangement2 it should be 100mm. Is it possible to have different value for the same distance constarint in different arrangements?
Ganesh
Re: Vary constraint value in different arrangements
make the distance constrains arrangement specific.
Right mouse click on the constraint
after that edit in arrangement too specify which value for the specific constrains.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Well..its so simple. Thank you for the answer! Smiley Happy
Ganesh
