Vehical Design Automation - Check parts according to ECE-R 26
Hi everybody,
pls give me some answer: Is it possible make in Vehical Design Automation check of part according to ECE-R 26?
Gr
3 REPLIES 3
Re: Vehical Design Automation - Check parts according to ECE-R 26
You could us toolpath with a 100mm cutter to idetify the contact points. Then use the minimum radius analysis display to check the radii.
Steve V
Thank you Steven,
it is very good advice. But i gues, if is there some automation for cars design, it will happen automaticaly.
In other PLM is possible under Licence for Car Design Check make ECE-R26 automaticly and in our company is this Analysis much used.
For me will be useful to know usual praxis by design check
in NX.
Gr
Could you create an ER in GTAC detailing exactly what you would like to see from such a function. We can then review it and see if we can get it into a future version.
Steve V
