View Scale
Hi there,
Is there a way to take the View Scale instead Sheet Scale?
I've been using that syntax to take it:
SCALE <W@$SH_SHEET_SCALE_NUMERATOR>:<W@$SH_SHEET_SCALE_DENOMINATOR>
But all times that I place the view I need to edit Sheet Scale.
Bauler
NX 12.0.1
11 REPLIES 11
Re: View Scale
Do you NEVER place 2 views on a sheet at different scales?
Note if you edit the sheet scale, ALL the view scales will be changed to match the sheet scale
Re: View Scale
Hi @Ken_A
I do, but every times that I place views I need to change Sheet Scale to take it automatically in title block.
Re: View Scale
OK...
What do you want on the title block in this case:
- Open a new drawing & sheet
- place a view at 1:1 scale
- place 2 projected views at 1:1 scale
- place a detailed view at 2:1 scale
Seems to me you should have 1:1 in the title block, and call out the scale on the detailed view.
Ken IANAD Akerboom  (IANAD = I am not a drafter ;-)
Re: View Scale
Honored Contributor
Honored Contributor
Personally, I hate the drawing sheet scale.  I prefer to have the scale of the view, under the view, so the user of the drawing sees it.
-Dave
Re: View Scale
@Ken_A
That's ok when you can place 1:1 scale views, but on practice you don't have it.
Re: View Scale
OK, let me change my example.
- place a view at 1:10 scale
- place 2 projected views at 1:10 scale
- place a detailed view at 1:5 scale
Seems to me you should have 1:10 in the title block, and call out the scale on the detailed view.
If (per what I think you're asking for) the scale in the titleblock should change to 1:5, now you have 3 views you have to put the "SCALE: 1 : 10" label on
Re: View Scale
To continue...
To me, the scale on the title block should match the scale of the majority of the views.
Then any "other scale" views need to be labelled.
If you have the same number of views in 2 different scales, then you pick one for the title block & label the others.
If you want to change the scale of a bunch of views (e.g. "ooops the part just grew too big to fit on the sheet") then change the sheet scale & all the views will update to the new scale (you may then have to go back & reset a detailed view scale)
If this isn't what you're talking about, please post an example like mine describing the desired behavior
Dave - just leave it off the title block (probably not your decisiion) ;-)
Re: View Scale
Honored Contributor
Honored Contributor
Always above my pay grade Smiley Happy
...and what if I plot the drawing at 1/2 scale, then what should the drawing and view scales read?  or worse yet, I print the drawing and it just fits it to the sheet at some random scale?   I think this is why many drawing formats are labled, "Do not scale" Smiley Happy
-Dave
Re: View Scale
Hi @Ken_A
"To me, the scale on the title block should match the scale of the majority of the views."
It is what I want to do automatically. Do your NX has that behavior?
NX 12.0.1 | Windows 10 | TC 11.4
