Viewing Component Groups
Hello, I'm starting to work with component groups and have managed to create a component group and then add components to it.  While seeing the component group in the Assembly Navigator Tree, is there any way for me to see where the components are in the assembly?  I select the component group in the ANT, but nothing happens in  the main window.  Should it?  I guess I'm used to selecting components in the ANT and having them hilight in the main window.  Should I have changed some settings or values?  Thanks
Re: Viewing Component Groups
Have you tried right clicking the Component Group and selecting "Apply"?
Regards, Ben
That worked.  Thanks!
