Visual Parameter Editor
Hi Everyone
Can anyone guide me about Visual Parameter Editor in NX. And what its used for.
Re: Visual Parameter Editor
Check the NX documentation link 'Visual Editor'
Ashish --
The Visual Editor was a very early (around 20 years ago) tool for identifying key expressions that should be used to drive a model.  It's not bad for its time, and some people still use it (which is why it's still in the menus)but it's pretty limited by modern standards.
If you're looking for a modern way to package NX models for reuse, I'd highly recommend looking toward either "Reusable Components" if expressions are the only thing you need to change or "Product Templates" (created isng Ptoduct Template Studio, or "PTS") if your template models have geometric inputs (WAVE links) or you want to feed back numbers to the designer, or incorporate drawings or FEA or motion analysis, for instance.  :-)
Good luck!
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Tel: +1 (602) 441-0683
taylor.anderson@siemens.com
