Visualization Problem
I am trying to model, a simple extruded cylinder with some holes a chamfer and a radius;
I am able to create the features but I am not able to visualize the model correctly;
Something similar happened with some other parts, on which I am not able to visualize correctly the hole model.
- I think that I have a set up correctly the Visualization Preferences, but I don’t know what to change.
Attached you will find images describing the issue, and two more images with the visualization preferences that I considered relevant, let me know if you need any other information.
Thank you,
Re: Visualization Problem
What kind of graphics card do you have in your computer?
Is it one of the certified cards?
http://www.plm.automation.siemens.com/en_us/support/gtac/certifications.shtml#lightview%26url=/en_us... (Graphics Card) Certifications%26description=%26docType=xls
If it is a supported card, is the driver a certified version (or later)?
do you have try set the Ctrl+F button command?
