Visualization performance
Builder
Builder
every start NX or change window in NX activate automatic "Disable Transluency" in Visualisation Performance. How to turn off?
NX10 MP6
3 REPLIES 3
Re: Visualization performance
That setting is stored in the Windows Registry
HKEY_CURRENT_USER\SOFTWARE\Unigraphics Solutions\NX\10.0\Visualization (see image below).
If set to 1, then it is not enabled in NX (which is what you want).
It's possible that your permissions for the registry isn't allowing that setting to change.
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
Builder
Builder
Thank you, it works.
Builder
Builder
Radomly open NX and Transluemcy is back to disable (and settings in windows registry).
