WAVE references warning
Honored Contributor
Honored Contributor
occasionally we will get an informational warning message regarding wave links, that refers you to the Teamcenter Integration section of the customer defaults.  Looking into this more, trying to figure out if its set the way we desire, or not, and the pop-up tip isn't overly informative, and for that matter, I could be in the wrong section.
First, IS this what the warning is refereing to?
and if so, am I interpereting this right...
Item Revision to Item, would tie the link between the particular Item Rev I am working on, to the Item (latest revision?).  VS. Specific Item Rev (dataset) to specific Item Rev (dataset)?
Thanks!
-Dave
3 REPLIES 3
Re: WAVE references warning
Honored Contributor
Honored Contributor
I think I'm on the right track, but missing an option referred to in the warning message, and help files.  I don't see the options for none, warn, etc.  Is this a bug or a misunderstanding on my part?  @BenBroad?
-Dave
Hi @DaveK,
It looks like you have comprehended the documentation's explanation, except for the fact that the message option for inconsistent revisions is found in the Teamcenter Integration Preferences, not the Customer Defaults, when WAVE Relations is set to Dataset to Dataset.
Regards, Ben
Honored Contributor
Honored Contributor
Of course they would have settings in two nearly identical places Smiley Happy
-Dave
