Wall Thickness Check with Symbolic Threaded Holes
I'm looking for methods that others are using to accurately check wall thickness where symbolic threads are being used. Curves get generated to show where the depth of the threads are. However the real geometry is set to the minor diameter thus not including the threads in the calculation. Any suggestions other than using detailed threads?
