Wave linked body and PMI
What kind of PMI can be applied on a wave linked body?  I had a pattern of holes on a component which I wavelinked. However, it does not recognize the "Hole call-out" . What are the guidelines to applying PMI on linked bodies?
Re: Wave linked body and PMI
I think hole call out will not work on linked bodies since linked bodies has no parameters but still you can apply simple PMI like angular, rapid, etc. which is more on measuring.
PMI needs to know somehow the parameters of the feature you are working with.
However it will work on your parent model based on your standard that is set in your PMI.
Sen
