Way to cut though multiple parts at once ?
Hi (Cutting through multiple pcs in assembly possible ?)
Is there a way to cut through(normal cut or extrude cut) many parts in an assembly so that all parts are modified at the same time ? (Now I go and individually change all parts)
Like if an assembly has many overlapping sheetmetal parts and I want to make a hole / cut through all of them at the same time:
Re: Way to cut though multiple parts at once ?
Will "ASSEMBLY CUT" work for you?
