Weight of multiple bodies with New NX measure
How can I measure the weight of multiple bodies with the new consolidated NX measure?
Our designers complain that you could simply drag a window over some bodies to get the weight with the old measure body command.
That’s not possible with the new measure and I don’t even know how to create a single weight measurement of multible bodies.
Does someone know how/if this works with the new measurement?
Re: Weight of multiple bodies with New NX measure
Found the solution --> Object Set
Hi @Klaus
FYI, There is a knowledge base article as "NX12.0.2 Measurement Commands Consolidation" where @TaylorAnderson have explained the "New Measure" command very well.
