Weld / Balloon leader on circular(radius) feature ?
Hi
How can I place a leader of weld / balloon on circular(radius) feature ?
  • Leader attaches always to circle's / curve's centerpoint and not to the line itself. :-(
Re: Weld / Balloon leader on circular(radius) feature ?
Yes. Succeeded. Here is how I did it. Use "Point On Curve" :-)
Hello @12131444,
Besides the optoin you have used. I believe you will also see a different behavior, if you approach the cirle from the inside, or from the outside. At least this works with applying dimension to circles. So I guess htis will work with leaders as well.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
