When 3D part is read-only in Teamcenter is there a way to export its .DXF file ?
Hello
When 3D part is read-only (formula flagged) in Teamcenter is there a way to export its .DXF file ?
  • Export -> DXF -> "File read-only" error.
Re: When 3D part is read-only in Teamcenter is there a way to export its .DXF file ?
If it is read only for you then you will not able to make any changes.
Do you mean that export DXF when part geometry is open in NX (managed).
Does DXF dataset is already available under the item revision of that particular item?
Ganesh
Can TC's main user cancel "Approved checkered flag"-status ?
- I must insert a DXF dataset under some Parts in Teamcenter.
Is the only way to make a revision out of the part in TC ? So I could add the DXF datasets
You can have your Teamcenter Admin Unlock the Item revision so you can add Datasets to it.  If you do not want to make a new revision.
Or you may be able to create the DXF file as a native mode file, and have the TC admin create/import that file to the correct dataset.
IMHO somewhat less dangerous that unlocking the item rev.
