Why NX rendering engine doesn't support workstation GPU ?
Hi Siemens PLM team,
All rendering software use GPU.
Thank you..
Using NX1880 and RuleDesigner PDM
Built-in functions for converting units of measure
Re: Why NX rendering engine doesn't support workstation GPU ?
Hi @cubalibre00
NX DOES use GPU rendering in Ray Traced studio, but only with NVidia (as it is based on IRAY+)
It even supports Remote rendering.
Documentation says:
"NX uses multi-threaded, hybrid CPU/GPU based, Iray+ technology to display real time inter-object reflection, refraction, and global illumination effects."
and:
"To maximize rendering performance, an NVIDIA GPU with CUDA Compute Capability 2.0 and higher, and a graphics driver supporting CUDA 8.0 or higher"
Johannes
Hi @Johannes_H ,
thank you for the rapid answer.
I asked this because for my test I diden't used ray traced studio but only the studio task without enabling ray traced windows.
Thank you..
