Wing profile dimensioning
How to dimension chord length,max. thickness of wing profile,and distance in projected direction in drafting.
14 REPLIES 14
Re: Wing profile dimensioning
Make a sketch in modeling with the chord and pitch circle. See attached PDF
Kurt Neubaecker
CAD/CAM Designer
Proficient Industries
Cleveland, Ohio
Attached is the prt file to see constraints used.
Kurt Neubaecker
CAD/CAM Designer
Cleveland, Ohio
I can tangent circle only at one end of the profile,I don't have tangency on other end.In your example profile is almost symmetric,since tangency point determines distance (radius) I need to make sure that my tangency point is at extreme end.How to find tangency point in this example?
Can you upload your wing profile?
Kurt Neubaecker
CAD/CAM Designer
Cleveland, Ohio
Thanks for help!
See attached.  Make the tangent constraints to the bridge curves you used to create the profile.
You can only have one tangent constraint on a closed profile. If you did not have the bridge curve you could just extract curves and trim them so you have one curve at the LE and one at the TE.
Kurt Neubaecker
CAD/CAM Designer
Cleveland, Ohio
I can' t open the file.What nx ver. are you using?
NX 12
Kurt Neubaecker
CAD/CAM Designer
Cleveland, Ohio
Attached is a video of the process if you can not open NX12 files.
Kurt Neubaecker
CAD/CAM Designer
Cleveland, Ohio
