Wood carpentry Library
Hi, is there any library for wood carpentry/furniture design? Like door hinges, sliding guides for drawers and so on? Amon the standard reusable parts I cannot find anything.
Thank you
Re: Wood carpentry Library
NX does not provide those types of standard parts. I suggest looking on the internet. AutoCAD probably has a lot of woodworking parts available. Remember you can import DXF/STEP/IGES files into NX.
thank you Ron
